S53M will not drive
  • Hi.
    My Simson S53M can run idle, but not good. When i try to rev up, the engine will just stop.
    The caburator is new (bought yesterday) and the engine is just renewed. We (me and my dad), think it could be the ignition, but we are not sure. Everything at the moped looks fine.
    Even a danish moped mechanic can\'t fix it. Maybe because a Simson is a very rare moped in Denmark.
    Do you know what\'s can be wrong? or do you know a good moped mecanic in Germany that can fix it? We won\'t drive too south in Germany, so please tell me one near Denmark (not souther than Berlin)
    Sorry for my bad english.
    /Dennis.
    .. A Danish Simson driver
  • first we need to know wich ignition you have: PVL, VAPE, Electronic
    is the caburator adjusted?
    is the gas slidegate valve in the correct position?
    wich caburator you have installed?
    how large is the main jet in the carbuator?
    i think the problem is the carburator as you got not enough gasoline into the motor
    den er bevorzugt"
    (Friedrich II. / 30.Dez.1782)
    (Friedrich II. / unbekannt)
    (irish wish, unknown)
  • 1. The ignition is Electronic
    2. Yes, the caburator is adjusted
    3. Yes, the gas slidegate vave is in the correct position.
    4. I have installed this caburator: http://www.a-k-f.de/shop/produ…1--1103--bis-60-km-h.html
    5. The main jet is 15mm (if this is what you are thinking about)
    Original von Dk-dda:
    Impossible! The main jet is 0,68mm! And this carburator do not work with your power filter!
    Simson ist ein Virus 8|
    Hubraum ist durch nichts zu ersetzen...
    Original von merci_pur:
    I thought the main jet was something else. I did not understand what he meant by that. And I\'m not using my power filter! I sold it to my friend.
