Is this tuning set good?
  • you have to change the crank shaft cage!
    =Umbau des Kurbelgehäuses erforderlich
    the Prize is ok, i guess... But i dont like this Exhaust!
    If the police is clever enough they will recognize that this is illegal!
    Furthermore with this Exhaust you have to drive with high revs !(Drehzahlen? heißt das so??)
    hope you can unterstand it :rolleyes:
    Original von xXS50Xx:
    Yes, I understand what you mean. Thank you for the help.
    But i don\'t want to use this set on the street. Only when I go to street races.
    Will this set make me a lot faster?
    .. A Danish Simson driver
  • Very nice home page you have found. I will take a look on it!
    But are you sure that i can use all these engines on my S53M?
  • @ xx
    the s53m is the normal s53 frame but it has only a \"mofa\" permission
    @ dk dda
    i think for the set from A-K-F you will also need an other crank
    mfg der rider :b_wink:
    wer eintopf fährt muss kräftig rühren^^
    es wird eine zeit kommen, in der du mitunter andere leute kennenlernen wirst, die weitaus effektiver an der nachbildung von cross schutzblechen beteiligt sind...
  • Hi!!
    whwn you looking at a verry fast engine, you must see this page: http://www.reichtuning.de
    Here you will find a lot of parts, they let you be the king of the streets
    sorry for the bad english
    [f3]S51E[/f3], Bj. 1989, Waldmopet mit verlängerter Vordergabel und langen Federbeinen, 70ccm von Mühli und 20er BVF
    [f3]S51B2-4[/f3], Bj.1986 115ccm von Reichtuning mit 20,5BVF ,5Gang mittel; Vape
  • So if you want a really good engine for Racing, you can do a lot of things...
    But first you have to know what you really want..
    50/60/70cc
    high-end-racing or more a solid working engine, you must imagine that high-end-racing is very expencive and you\'ll have to spend a lot of time/work in it.
    have a look at this:
    Blog of FKKracing
