Kugellager und Wellendichtringe
  • [table=#FFFFFF,100%,1,center]
    [tr]
    [td=#FFFFFF,20%,left] [/td]
    [td=#FFFFFF,20%,left] M53 Motor[/td]
    [td=#FFFFFF,20%,left] M531/M541 Motor[/td]
    [/tr]
    [tr]
    [td=#FFFFFF,20%,left] Kugellager[/td]
    [td=#FFFFFF,20%,left] Wellendichtringe[/td]
    [/tr]
    [tr]
    [td=#FFFFFF,20%,left] DIN 625[/td]
    [td=#FFFFFF,20%,left] DIN 6504[/td]
    [/tr]
    [tr]
    [td=#FFFFFF,20%,left] Kurbelwelle, rechts[/td]
    [td=#FFFFFF,20%,left] 6306 TN C4[/td]
    [td=#FFFFFF,20%,left] 22 x 47 x 7 innen[/td]
    [td=#FFFFFF,20%,left] 6204 TN C4[/td]
    [td=#FFFFFF,20%,left] 20 x 47 x 7[/td]
    [/tr]
    [tr]
    [td=#FFFFFF,20%,left] 17 x 28 x 7 außen[/td]
    [/tr]
    [tr]
    [td=#FFFFFF,20%,left] Kurbelwelle, links[/td]
    [td=#FFFFFF,20%,left] 6303 TN C4[/td]
    [td=#FFFFFF,20%,left] 22 x 47 x 7[/td]
    [td=#FFFFFF,20%,left] 20 x 35 x 7[/td]
    [/tr]
    [tr]
    [td=#FFFFFF,20%,left] Kupplungswelle, rechts[/td]
    [td=#FFFFFF,20%,left] 6000 F C3[/td]
    [td=#FFFFFF,20%,left] - [/td]
    [/tr]
    [tr]
    [td=#FFFFFF,20%,left] Kupplungswelle, links[/td]
    [td=#FFFFFF,20%,left] 6203 F C3[/td]
    [td=#FFFFFF,20%,left] 6303 F C3[/td]
    [/tr]
    [tr]
    [td=#FFFFFF,20%,left] Antriebswelle, rechts[/td]
    [td=#FFFFFF,20%,left] 17 x 28 x 7[/td]
    [td=#FFFFFF,20%,left] 6004 F C3[/td]
    [td=#FFFFFF,20%,left] 20 x 30 x 7[/td]
    [/tr]
    [tr]
    [td=#FFFFFF,20%,left] Antriebswelle, links[/td]
    [td=#FFFFFF,20%,left] 6201 F C3[/td]
    [td=#FFFFFF,20%,left] 16004 F C3[/td]
    [/tr]
    [tr]
    [td=#FFFFFF,20%,left] Kupplungsdeckel[/td]
    [td=#FFFFFF,20%,left] Handschaltung[/td]
    [td=#FFFFFF,20%,left] 22 x 35 x 7[/td]
    [/tr]
    [tr]
    [td=#FFFFFF,20%,left] 14 x 30 x 7 [/td]
    [/tr]
    [tr]
    [td=#FFFFFF,20%,left] Fußschwaltung[/td]
    [/tr]
    [tr]
    [/tr]
    [/table]
    [tr]
    [/tr]
    [tr]
    [td=#FFFFFF,20%,left] Räder[/td]
    [td=#FFFFFF,20%,left] 6201 2 Z C3[/td]
    [/tr]
    [tr]
    [td=#FFFFFF,20%,left] Hinterradantrieb[/td]
    [td=#FFFFFF,20%,left] 6203 C3[/td]
    [/tr]
    [/table]
  • wenn ich da mal ne frage einschmeissen darf :
    ich hab neue dichtringe ( alle ) beim s50b motor reingemacht jetzt sind die mittelteile wieder zusammen und die kurbelwelle läst sich total schwer drehen is das richtich ?? hab die dichtungen mit fett eingesetzt.
    danke
    mfg :b_wink:
    __________________________________
    :b_wink: MfG Kevin :b_wink:
    der mit dem Sr50b4 sorgenkind
  • ja die sind gewechselt....aber es geht so schwer das ich das nichmal ankiccken kann. ich kann mich auf den kicker drauf stellen und dann sink ch ganz langsam nach unten. liegt aber an der KW das getriebe ist leichtgängich
  • dann ist die Kurbelwelle ein bischen verspannt. Hau mal mit nem Gummihammer auf das Motorgehäuse. Damit lösen sich einige Verspannungen.
    Wie gesagt, wenn der Motor dann erstmal läuft, dann wird die immer leichtgängiger, da sie dann in die richtige Passung rutscht...
  • halöle....
    ich hab das mit dem gummihammer mal gemacht und immernoch keine veränderung ....die kw dreht sich immernoch total schwer :crying:
    gibts noch ne möglichkeit was das für ein problem sein könnte ??
    danke
    mfg :b_wink:
  • also es kann schon was verkantet sein, aber spalten würde ich erstmal nicht!
    am besten:
    backofen auf 80-100°C und den motor ne viertel stunde reinstellen! danach alles ordentlich mitm gummihammer bearbeiten UND nochmal alle schrauben nachziehen!
    damit hab ich schon mehr als einmal SOLCHE probleme gelöst :b_wink:
  • Und wenn man's gleich richtig macht treten solche Probleme gar nicht erst auf.
    Schonhammer ist deutlich günstiger als Gummihammer.
